new diff setup questions?
supermaxx4190
supermaxx4190's Avatar
new diff setup questions? - 04.04.2005, 09:33 PM
hey there,
i think im going to UE 6 spiders and im not sure what diff oil to run. i run the 8L on 12 cells. also, i run 16/72 gearing, what would be the equvilant for the UE diffs. i would also like to know the formula to find gearing from stock diffs to UE diffs if anyone knows. thanks
Isaac
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.05.2005, 02:40 PM
I use 5000 weight in the diffs (front and rear). Some run stiffer oil in the front for better on power steering, but I like off power steering (just the way I drive). Basically, drop add two teeth to your pinion when going to the UE diffs for a similar ratio.
Chase023
Chase023's Avatar
04.05.2005, 03:04 PM
Can Anyone spare some shims for the UE Diffs??
I need a few of those 0.010 shims
Embrace the Speed!
 Send a message via ICQ to Chase023 Send a message via AIM to Chase023
Serum
Serum's Avatar
04.05.2005, 03:50 PM
If your interested, i can find a partnumber of a 8 mm shimset (.1, .2 and .3 mm thick, 10 of each) it's from kyosho.
And i found a shim set from Tamiya of 10 mm shims..
You can buy the setup kit from UE as well.
supermaxx4190
04.06.2005, 06:32 PM
im thinking 10000 in front and 7000 in rear. how would this be?
RC-Monster Mike
Site Owner
04.06.2005, 10:22 PM
It would work very well. It would pull harder than the 5000 out of the corners, and have slightly more on power steering (and slightly less off power steering).
supermaxx4190
04.09.2005, 04:29 PM
i got them today. they have 7k front and 5k rear. think that wil be good?
RC-Monster Mike
Site Owner
04.10.2005, 06:59 PM
That will work very well.
