i need help!!
BlackedOutREVO
i need help!! - 02.13.2007, 02:30 PM
ok guys my nimh pack was runnin ok and then it just stops, i temp it and 2 cells were 190 degrees f and all the rest were 110 so im sick of these stupid packs with no run time and they dont give very good voltage so
im going lipo!!! YAY!!!
i want limh for my flm mamba pede with 5000 mah if theres one, or close, any recomendations??
and then i will have lipos for my cars but in the pede that i BASH HARD i need something a lil more stable//
i know chc runs these packs, and they do well.. so i want in lol
and last how do i charge them? i will get a super brain 989, and i dont know if i need a ballancer or not?
thanks:018:
BlackedOutREVO
02.13.2007, 02:39 PM
actually scratch that.... 220 bucks is too much lol for the 3 cell
heres what i want, is this good? its what byt used..
http://www2.towerhobbies.com/cgi-bin...p?&I=LXMUV9&P=
EDIT: will my mamba max 5700 kv motor handle the 3 cell limn? or no, or do i need a ubec? if i have to do the ubec or whatever i will just get the 2 cell one
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
02.13.2007, 04:05 PM
you can get that pack from mike.
they are very powerfull and most of all safe.
losi 8ight-t
xray xt8
BlackedOutREVO
02.13.2007, 04:11 PM
but will my mm handle it or no???
and i know mike has them, i foun them there first
jollyjumper
RC-Monster jumper
02.13.2007, 04:14 PM
you should adjust gearing and it will be fine.
lower tooth pinion or bigger spur, to compensate for the higher voltage.
your on 8 cells nimh, or not?
thats 9.6V, limn 3s is 11.1V
losi 8ight-t
xray xt8
BlackedOutREVO
02.13.2007, 04:54 PM
howed u kow i was running 8 cells??? lol
and right now im running 83/17 gearing soo what? i have a 19 tooth pinion, would that be good????
jollyjumper
RC-Monster jumper
02.13.2007, 05:21 PM
i know your truck ;)
the FLM pede.
no you would need 14 tooth pinion or so.
did i say bigger pinion?
losi 8ight-t
xray xt8
jollyjumper
RC-Monster jumper
02.13.2007, 05:22 PM
how big are your tires, i'll calculate for you.
losi 8ight-t
xray xt8
BlackedOutREVO
02.13.2007, 08:26 PM
umm there almost 5 in
there narrowed moabs now, and they baloon but not really bad, but they will ballon easily another 1 1/2 inch balloned
and the smallest pinion i can run is 15, so do i need 86 tooth spurs? all the setting on the mm will be at the lowest possible:018:
jollyjumper
RC-Monster jumper
02.14.2007, 01:54 AM
i would use the 90t spur, your truck will still go like stink.
losi 8ight-t
xray xt8
Sylvester
Sylvester's Avatar
02.13.2007, 06:11 PM
3s should be fine on the mm.. if it does get hot, you can try a ubec.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
BlackedOutREVO
02.14.2007, 02:32 AM
why would i be gearing it for more torque???
and i dont really want to buy tons of stuff so idk.. i will figure it out when i get there
jollyjumper
RC-Monster jumper
02.14.2007, 02:50 AM
i'm kinda worried with heat, cuz your pede is on the large side for the MM motor. but yeah, test it with gears you got first.
sorry if i confused you, i was only trying to help.:002:
i run my mm5700 on 2s and with 4" tires.
i run 12.96/1.
losi 8ight-t
xray xt8
BlackedOutREVO
02.14.2007, 03:04 AM
yeh i understand now lol
and it really depends on how often and hard it hit the brakes makes the difference of 100 to 150 lol but one speed run and its cool again
and are the limn packs worth it? i can get lipos for cheaper, but idk
jollyjumper
RC-Monster jumper
02.14.2007, 03:10 AM
they are a tad safer, but if you dont wanna pay that much if i where you i'd just take lipo.
losi 8ight-t
xray xt8
