540C 7XL mounting problems E-MAXX
sapper_triple6
Student of RC-Monster University
sapper_triple6's Avatar
Question 540C 7XL mounting problems E-MAXX - 02.13.2007, 07:23 AM
I just got my 540C 7XL today and when I mount it I cant get the gear mesh correct because the heat sink is hitting the transmission case. Does anyone know if I can just take a dremel to the heat sink where I need more room or if I have any other options with this.
  Send a message via Yahoo to sapper_triple6
HotnCold
HotnCold's Avatar
02.13.2007, 08:03 AM
You could try a bigger spur gear - in turn moving the pinion further from the trans case - or you could dremel a bit away - either option would work...
Hows that "Hope and Change" working out for Ya???
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.13.2007, 11:24 AM
There was the exact same thread just a few days ago but with a Neu motor... he ended up dremeling the fins.
That's what I would do if a gear swap isn't an easy fix.
btw I just checked the cans...
Neu dia: 1.72"
540c dia: 1.69"
C50 dia: 1.70"
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
sapper_triple6
02.13.2007, 11:56 AM
looks like dremeling is the way to go since I am running the strobe slipper, and its only like 3 fins that I have to take a little off.
Thanks for the help!!!
jhautz
jhautz's Avatar
02.13.2007, 02:05 PM
The Gorilla Maxx motor mount solves this if you are using the Gmaxx chassis.
to make it...
or break it...
Silent...But Deadly
sapper_triple6
02.13.2007, 04:09 PM
nope just running the stock chassis for now
AAngel
02.13.2007, 04:41 PM
This is the reason why I didn't go with the "C" motor. I just went with the RC Monster heat sink. You can position where you need and it's thick enough to drill and tap to mount a fan.
sapper_triple6
02.13.2007, 04:48 PM
that was the actual plan to begin with but everything other than the c motor was out of stock and I needed a motor to fulfill my appetite for now.
AAngel
02.13.2007, 11:35 PM
I know what you mean. I have that compulsive instant gratification need too.
wallot
wallot's Avatar
02.14.2007, 03:30 AM
actually sometimes even the gorilla mount wont help. was trying it yesterday if by any chance i can fit even the 14T pinion by modifying motor mount and no chance. still 1mm more needed.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
neweuser
neweuser's Avatar
02.14.2007, 02:08 PM
This makes me glad I went to the wnaderer style motor with the RCM heatsink.
sapper_triple6
02.14.2007, 03:24 PM
Well I did the dremel thing and everything turned out fine, you cant even really notice I did anything when it is on the truck
neweuser
neweuser's Avatar
02.14.2007, 03:57 PM
then it worked out well for you
standard_63
standard_63's Avatar
02.15.2007, 04:55 AM
How much difference do the fins make over the smooth can? Anyone know for sure? They are there for more than looks, right?
Please tell me that's not smoke I see!
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
02.15.2007, 05:07 AM
smoothies are 1.40" and feigao 540c is 1.59 i think.
losi 8ight-t
xray xt8
