larger delrin/plastic spur for jammin crt conversion
strodedawg
larger delrin/plastic spur for jammin crt conversion - 03.08.2007, 09:13 AM
i have the kyosho spur on my jammin crt but need something slightly larger. i have read that people are using a 56t spur and the ofna 51 tooth spur. what parts would i need, with their part numbers to mount either one of these spurs.
thanks again
jim
let's build something sick!
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.08.2007, 09:45 AM
Send me an email, Jim. If you like, I can make a diff adapter to mount the 51 tooth ofna spur to the CRT diff.
Aragon
03.08.2007, 12:10 PM
I think I might have been the one mentioning the 56T spur. I have had a custom 56T spur made up for my project and will be converting the stock 48T steel spur into an adapter plate. I really need bigger than 51T for my planned power system.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.08.2007, 12:15 PM
Mike, an adapter would be cool.
What I did is use a Savage 51 tooth gear grafted onto a Kyosho gear with teh teeth shaved down to fit insid the larger gear. It actually works great and isn't too difficult.
But a real adapter is the proper way to do it for sure.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
RC-Monster Mike
Site Owner
03.08.2007, 01:15 PM
The ofna 64 tooth ofna gear will also fit. I can't imagine needing a larger gear than that!
Defcon
03.08.2007, 08:31 PM
Does anybody have a part number for the Ofna 64 tooth spur?
MetalMan
MetalMan's Avatar
03.08.2007, 10:24 PM
I think it's actually a 65t spur:
http://www2.towerhobbies.com/cgi-bin...?&I=LXABJ0&P=7
