hybrid question
meatzardd
#4
hybrid question - 04.10.2007, 07:57 PM
can the hybrids hold the stock gears, i was under the impression that they can hold stock gears and 1/8 scale?
Sylvester
Sylvester's Avatar
04.10.2007, 08:18 PM
The combo bulks hold the stock maxx type diffs, the hybrid bulks hold 1/8 scale diffs.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
meatzardd
#4
04.10.2007, 10:12 PM
so the hybrids wont accept the stockers at all? i knew the combo bulks carried the stockers.
DickyT
04.11.2007, 10:43 AM
correct, the hybrids will not fit the stockers, only the combos will.
The only difference between the combo and hybrid is the diff that it houses. 1/8 buggy diffs for the hybrid and stock size for the combo.
I have the combos installed for a few weeks (30+ bash sessions) and love them so far.
meatzardd
#4
04.11.2007, 01:29 PM
alright thanks ill get the combos then.
Serum
Serum's Avatar
04.11.2007, 02:26 PM
Be sure to get aluminum diffcups as well! they are a must for using stock diffs. (get them with M3 thread for the ringgear)
meatzardd
#4
04.11.2007, 04:05 PM
which is the toughest upgrade e-maxx diffs? i really dont want to go wit 1/8 diffs so whats my next best option?
Sylvester
Sylvester's Avatar
04.11.2007, 04:35 PM
7075 maxmizer diff cups with RRP gears.
Losi 8ight e
skellyo
skellyo's Avatar
04.11.2007, 04:58 PM
Although this is the best option with using stock sized diffs, with only a small cost difference between that option and the Hybrids/HB Lightning diffs, I'd go with the Hybrid/Lightning diffs. That way, you never have to upgrade again. I think it's only about $40 more for that option. Heck, you could even eBay your stock bulks/diffs to recoup $15-20 of that.
squeeforever
squeeforever's Avatar
04.11.2007, 07:32 PM
Besides, 1/8ths are tunable with fluid which really helps with brushless.
meatzardd
#4
04.11.2007, 09:55 PM
you guys are the worst, now i have to get the hybrid/lightning.:005:
what thickness of fluid do you guys run in your diffs?
DickyT
04.12.2007, 09:23 AM
I only bash... I run ofna high temp green diff lube up front and ofna diff lock lube in the rear.
The diff lock lube make it drive like I have a spool installed unless extreme force is applied to a rear tire, then it will allow diff action.
RCShocker
RC Monster
04.16.2007, 06:24 PM
I'm sure it is simple but how is it applied into the diff's? What is the consistency like?
SmokinAces
Driving with the brakes on...
SmokinAces's Avatar
04.17.2007, 12:57 AM
I wonder when the Hybrid diffs will be back in stock. I want to get a couple sets as well.
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
04.17.2007, 01:55 AM
i would assume DickyT packed the diff cups with the diff lube.... right dicky?
i packed my aluminum diff cups with this stuff (the back cup is practically airtight - it slows the diff action, but not too much. the front has a bit less. the consistency is about that of toothpaste... maybe just a bit thinner).
Eflite Blade 400 heli on 3s
