Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
supermaxx EXT pro users?
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
supermaxx EXT pro users? - 04.20.2007, 01:04 AM
hey guys - i just picked up a slightly used EXT pro kit. as usual, i was in a rush and didn't pay attention to the details... it's not the 'full kit'. it didn't come with towers, but that's ok - i'm running knuckleheads. but, i noticed it also doesn't come with the turnbuckles... grrrrr.... will the 2.5 length lunsford ti buckles i have now work? or are the EXT buckles a bit longer due to the increase in width? i suspect they are longer, as UE's site shows regular buckles as well as EXT buckles, which would lead me to assume there is a difference. i won't have the set for a week or so, maybe less, and i just wanted to check with you guys first.
here's a shot of what i bought:
(oh, and UE has the rear buckle set in stock, but not the front. i hope i don't need them and can use what i have! the patience of a saint is needed when something is out of stock at UE. maybe i'll email mike and see if he has any EXT buckles.)
thanks a kajillion! :)
edit: i'm not sure why the image isn't showing up, but did i just buy EXT Pro or WideMaxx Pro?
Eflite Blade 400 heli on 3s
Serum
Serum's Avatar
04.20.2007, 01:50 AM
EXT pro, since the upper side of the knuckle is longer, and the upper a-arm is shorter.
The standard maxx 2.5 wide maxx tb's should fit. I am using the racer-X (which is about the same on the front) and that uses the standard tb's in front as the 2.5 wide maxx.
ClodMaxx
ClodMaxx's Avatar
04.20.2007, 08:04 AM
whew! thanks serum!!
Serum
Serum's Avatar
04.20.2007, 10:35 AM
Check to see if it has got 16 or 15mm od bearings.
id needs to be 6 to be used with stock sized cvd's.
Serum
Serum's Avatar
04.20.2007, 10:36 AM
15 was used on the earlier version, and 16 od is used on the newer editions.
ClodMaxx
ClodMaxx's Avatar
04.20.2007, 10:55 AM
ok, i'll check. thanks for that heads-up.
i doubt these are going to come with any instructions on setup - are the arms marked front or rear? i guess i can try to see which ones are front/back from the pics on UE's site. i've only run stock arms up until now, so it'll be a challenge to get them set up right. i like a challenge, as long as it all fits the right way, lol.
thanks again!
Procharged5.0
Procharged5.0's Avatar
05.04.2007, 10:39 AM
thanks again!
Visit the UE website for installation & set-up instructions plu they have set-up sheets for you to mark how you set-up the truck for specific races, etc.
ClodMaxx
ClodMaxx's Avatar
05.04.2007, 10:46 AM
yeah, i found the EXT install instructions... but i don't think it mentioned the washers. i'll check again. thanks!
GorillaMaxx360
GorillaMaxx360's Avatar
04.20.2007, 07:36 PM
how much was that kit of arms and knuckles
ClodMaxx
ClodMaxx's Avatar
04.20.2007, 07:39 PM
$176.50 plus $8 shipping. :dft012:
ClodMaxx
ClodMaxx's Avatar
04.25.2007, 11:01 AM
ok. i 'test fitted' one set of arms/knuckles last night, and all i can say is... wow. the suspension movement is much more fluid, and the knuckles take so little effort to move them back and forth. this is an enormous improvement from the stock arms and knuckles. the arms fit like a glove where they attach to the bulks, with virtually no room for front to back movement. it all works very well with the racerX shock towers, too. this is some top notch stuff!!!
i still have to tear the truck down to install the FLM chassis with the EXT pro suspension, which i'll probably get to this weekend. but i can't wait to experience how much better the truck is going to handle!
GorillaMaxx360
04.25.2007, 11:08 AM
very nice
Mattymaxx
Mattymaxx's Avatar
05.03.2007, 06:24 PM
yet another satified UE customer.
Matt:027:
TM Bashers!
DVD No Limitation Nearly Here!
www.modellinc.com
ClodMaxx
ClodMaxx's Avatar
05.04.2007, 09:33 AM
very satisfied! :)
i don't think i'd pay the $463 that these things retail for new, but i got a good deal - and it's a huuuuge improvement over what i had.
there are only a couple problems i have to figure out. the first is the MIP cvd's - the dogbone end that sits in the diff cup is dangerously close to the end (this suspension kit extends the width of the truck, thereby pulling the dogbone end away from the diff). it still seats in the cup at full droop, but not by much. UE EXT cvd's will fix that, but it's another $120 + for a full set.
the other thing i've noticed is the knuckles seem to rub on the rim somewhere when i tighten the hex nuts down all the way. if i back off on the nut, they seem to clear. maybe another MIP problem that would be solved by UE cvd's??
Mattymaxx
Mattymaxx's Avatar
05.04.2007, 10:13 AM
right. There neews to be a washer inbetween the bearings in theknuckles, this will stop the rubbing.
As for the cvd's thats correct you will need the UE ext cvd's steel ones r plenty strong enuff. titanium or ott but u never no!
Many brushless users use titanium on rear and steel on front.
Hope this helps!
Matt.
TM Bashers!
www.modellinc.com
