Brushless help (savage)
AdmiralDog
Brushless help (savage) - 06.05.2005, 04:27 PM
I just bought a savage and will be converting it to electric. I think im getting a 9l for it. ill be running 12-14 cells only. Now, should i get the 1/8" or the 5mm shaft. Also what gearing should i start with. any ideas?
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
06.05.2005, 04:45 PM
5mm shaft definitely. It'll help take the abuse of a big monster truck like that.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
maxxdude1234
maxxdude1234's Avatar
06.05.2005, 04:47 PM
I would reccomend the 5mm shaft's, they are much much stronger than the 1/8" ones. Finding pinions can be harder, but rc-monster stocks many 5mm bore pinions.
As for gearing, I wouldn't know on for a savage. In my bl maxx I run a final drive ratio in 2nd gear of about 1:20....hope this helps
Serum
Serum's Avatar
06.05.2005, 05:14 PM
Hi admiralDog!
Welcome to the forum, hope you'll find the info you need here and if you don't find it feel free to ask!
Go for the 5mm!! no doubt. You need MOD1 pinions.
here is the sheet for selecting the right gears. There are 47, 49 and 52 spurs available from HPI.
If you are planning on running 14 cells, i would suggest using a 12 tooth pinion (Mike has got these normally in stock) it will go about 35 mph. you are going to use the stock two speed transmission with the mechanical brake?
AdmiralDog
06.05.2005, 05:25 PM
yeah i will prolly use the stock transmission with the mechanical brake. I might get the 3 speed if i feel like i need more speed. ill be useing 12 cells first until i buy some 7 cell packs. so should i use a 14 or 15 tooth then?
Serum
Serum's Avatar
What spur are you using?
AdmiralDog
06.05.2005, 05:27 PM
Stock one. Or should i buy a different one
Serum
Serum's Avatar
06.05.2005, 05:30 PM
what spur are you using?
stock ss has got a 49 tooth and the stock .25 or .25 a 52
and the K4.6 uses a 47 tooth...
AdmiralDog
06.05.2005, 05:39 PM
oh sorry.
I have a stock 21 savage.
i believe is a 52 spur gear
76942 SPUR GEAR 52 TOOTH (1M) (http://www2.towerhobbies.com/cgi-bin...=++&search3=Go)
Serum
Serum's Avatar
06.05.2005, 05:48 PM
on a 47 spur use a 12T/13T pinion. or use the 52 spur and a 13T/14T pinion.
Planning on buying a 9918 controller too?
AdmiralDog
06.05.2005, 05:54 PM
already got one. Im taking it from my BL rusty.
Thanks for the help.
Serum
Serum's Avatar
06.05.2005, 06:01 PM
It probably isn't a mod1 pinion?
AdmiralDog
06.05.2005, 06:06 PM
no, i bought a 6s 1/8" for my rusty and a 9918. Im selling the 6s and my rusty and then im buying a 9l for my savage.
Serum
Serum's Avatar
06.05.2005, 06:13 PM
My bad, i thought you where going to take the 13t pinion from the rusty... ;)
Did you allready figured out how to make the motorplate?
AdmiralDog
06.05.2005, 07:00 PM
yeah, i got a pretty good idea. What did you use?
