Plettenberg Powered Crt.5
Mailman
Plettenberg Powered Crt.5 - 09.03.2007, 12:16 AM
I started a thread in the temp forum when I got the motor in, and now I am almost done. I am waiting for my antenna mount, and I still need to get a battery. I also need to drill some holes in the battery mount to lighten it up, put a little foam padding on it and put the velcro strap on it.
I have only raced 18th scale for the last couple years and don't have any batteries other than 2/3A size, so I borrowed a Tyco 7.2v sub C battery (yeah thats right - TYCO) from a buddy of mine just so I could set the MM and get the steering servo centered and setup. After getting everything set I said what the heck and tried to see if it had enough juice to even run the thing. I was expecting it to cog, but to my surprise - it never did. I actually took it out in the street and drove it until the battery dumped - and not one cog. Anyways, here are the pics. The last one show the "please don't hit my expensive - it will burn up if punctured" battery guard. It is bent 90 deg. and keys into the notch on the bottom of the battery plate. I don't plan on using it all the time, just when racing or bashing with bigger trucks.
