6s is the limit I would go.. simple because I know a guy who tried 6s lipo and had 2 controllers fail. First then the replacment. He was told that he had overvolts and that they would not support him anymore. 6S A123 is obviously below the spec and closer to 5s lipos.
I went with the 9xl so that I could run higher voltage. 5s or 6s seems to make sense to me right now. It has to run cooler then a 7xl at the lower voltage.
I am thinking that the 5s2p maybe the sweet spot for me. I just need to find a way to test it without having a big hassle with Batteries.
For charging I plan on using zip chargers (8-10 min for a 3s pack. I'll run 2 at the same time and then I will take the 2s packs and put them in series and charge as a sinlge 4s pack at 8 amps on my hyperion charger.
So If I get 2 complete setups I can charge one while I run the other. The charge should take about 15-20 min. I most likely will only have battery swap as my down time :)
All this for a fair cost
$200 for dewalt cells (20 cells)
$200 for hypersion charger/balancer
$20.00 for 2 zip chargers
so for a total of $420.00 I can run 1 E-maxx nonstop for 1000 plus runs.
As a added benifit when I fly my combat planes I will have 4 3s packs and will be able to fly non stop also :) here is a funny one for you. The combat planes are cheaper then the trucks
They break far less I can crash them in midair or into the ground and most of the time the repairs if any are below 5.00. The cost of the planes is cheaper also. If there is anybody in the philly area that wants to check them out let me know, I could use a local truck guy to help me along on the E-maxx.
Highflier
