More CRT.5 Motor questions...
steve050773
More CRT.5 Motor questions... - 11.15.2007, 05:25 PM
I'm looking to pull together a Neu/MM setup in a CRT.5 that is flexible enough to run primarily on 3s and occassionally on 2s. The motors I've found so far in stock around the web are the 1509 1.5D 4500KV and the 1506 2D 5200KV. I'm not aiming for crazy speeds - mid 30's maybe - which I would think would be easily achievable with either motor and the right gearing. Just want good temps and decent run times.
Anyone have any opinions? Should I consider the real low KV 1509's (1.5y)?
Also, did anyone determine if the mounting bolt pattern of these smooth can motors is 540 or something else?
Thanks,
Steve
