Quark 125b
jacobsjo87
Quark 125b - 11.14.2007, 02:28 PM
I am almost done with my E-revo conversion and I am using a quark 125b on 5s with a Nue 1515 2.5d. I am new to the electric scene, do I need to program the quark 125b. Basically what do I need to do to get this thing going.
11.14.2007, 03:56 PM
You have to do the inital setup so that the controller will know the high, low and neutral of your radio system. If you are using a futaba radio, set the throttle channel to reverse, as the quark will not program with it set to normal. Also zero all trims and set the endpoints (if you have that setting) to the max. You do not need to adjust the std and adv menus to get it running, but you may want to depending on startup and battery preferences.
11.14.2007, 09:48 PM
Or, read the manual that came with the esc! That explains how to adjust all the other features such as lvc point, hard/soft timing etc etc.
