MGM mounting in 3095
hobbimaster
MGM mounting in 3095 - 01.11.2008, 04:36 PM
Whats the best way to mount a MGM 160 in the new maxx? I mounted mine using 2x tape, but after one run the Esc was warm making the tape loose. I wish the bottom were of plastic to mount it using the tape. I'm tempted to zip tie it to the shock tower.
Serum
Serum's Avatar
01.11.2008, 04:46 PM
welcome to the forum.
what version of the MGM have you got?
hobbimaster
01.11.2008, 04:56 PM
Opps sorry, its a MGM 16018 with the heat sinks on both sides.
Serum
Serum's Avatar
01.11.2008, 05:04 PM
you can use the 4 m2 screws to mount it onto something flat.
hobbimaster
01.11.2008, 05:08 PM
Ok, I see the 2mm screw holes. i'll try to dig up some lexan or something to make a mounting plate.
crazyjr
crazyjr's Avatar
01.11.2008, 05:37 PM
If it were me, I'd slot the chassis and mount it with zipties. It would allow more slip if you hit something hard
hobbimaster
01.11.2008, 05:48 PM
You know they make zip ties with the little screw hole "ears" that may work using the stock mounting screw holes from the originl ESC. Might have to give those a go.
neweuser
neweuser's Avatar
01.11.2008, 06:33 PM
Or use velcro like I do. :)
Serum
Serum's Avatar
01.12.2008, 04:08 AM
verlcro with glue, that stuff works miracles.
mkrusedc
NeuMaxx
mkrusedc's Avatar
01.12.2008, 11:20 AM
I used servo tape and zip ties. It has held well with very heavy bashing.
In the pic I hadn't zipped it yet
hobbimaster
01.13.2008, 03:05 PM
I found some 1" plastic mountaing squares at the local depot today. They have 2x tape on the bottom (good stuff) and these little slots on the top for slipping a zip-tie through it. It works very well without having to modify anything. Also in the pic I put together a switch mount since I had MGM include it when I ordered it.
01.13.2008, 07:50 PM
Resourceful. Its amazing what you can do with abit of plastic and some zipties....
t-maxxracer32
t-maxxracer32's Avatar
01.14.2008, 02:39 AM
if they didnt ever invent zip ties do you think RC would even exist?
i use them on SO many things its crazy.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.14.2008, 03:45 AM
Nope.
