Which NEU for LST2???
bluonyx
Which NEU for LST2??? - 03.21.2008, 08:12 PM
Is the Neu 1515/1.5y enough for a 13lb. LST2 on 4S?
I'm running a XLT1 from Fine Design now on a MM, but wanna take the leap to a Neu motor. I only bash so is 4S ok for now. I don't mind going to 5S or 6S but I'll have to get a new ESC too. Preferably 6S, so an MGM but Mike is always out of those too. Any suggestions?
I noticed Mike has them in stock again so I wanna get a couple before they go again.
bdebde
That's All Folks!
bdebde's Avatar
03.21.2008, 09:22 PM
5s or 6s would be better in a heavy truck. I really like 6s with 2.5D in my 12 lb truck.
satttheman
satttheman's Avatar
03.21.2008, 10:55 PM
If ur goin to do it go big get a 1521/1y it a beast of a motor on 5s and 6s I just one in my muggy and it out of control.
Projects:
FLM Savage
lutach
lutach's Avatar
03.22.2008, 01:52 AM
The 1521/1Y will make you have a silly smile on your face every time you run your truck. Mine with 6S is very fast. On 5S it will put any nitro down. I also tried it with 10S and the motor just transformed into a crazy out of control beast. Go with the 1521/1Y or you can try a 1521/1.5Y with 10S lipos.
03.22.2008, 10:52 AM
Do you have a video of your truck running on 10s, Lutach?
lutach
lutach's Avatar
03.22.2008, 12:17 PM
I will wait until the weather warms up a bit and I will make some speed runs with the current gearing and I have to go buy extra internal diff gears, because on that run it destroyed them. I was alone the day I ran my truck with 10S and didn't make a video. The power from 5S is incredible, the power from 6S is insane, but with 10S it seemed to have increased 10 fold.
lucias
lucias's Avatar
04.02.2008, 05:59 PM
I am working on a couple of conversion now and trying to decided what combos to go with.. I am total newb to electric..
What kind of run times did you get with a 6s? what mah?
What kind of run times did you get with a 10s? what mah?
lutach
lutach's Avatar
04.02.2008, 06:17 PM
I only ran a little over 9 minutes and only used 1685mAh out of my 4600mAh packs. Here is the graph http://www.rc-monster.com/forum/show...0&postcount=90 and I've just noticed I made a typo on the mAh. My run ended early because of my internal diff gears gave away. Too much power.
