does anyone know if someone makes a 46 tooth spur for the mbx-5 -
04.07.2008, 06:14 PM
I am looking for a 46 tooth for my mugen. I did the speed calulations and w/my setup...9xl,mm esc, 4s the top speed is 32 or so and this is w/ a 16t pinion...is this about right?
I only have 4s batts right now so I guess this is about right. Anyone else using a similar set up...would like to know your results
thanks
thanks
The stock spur is 46t? What happened to the stock gear?
Edit: I need to read before I post . My best guess is that he bought a used roller and someone might have changed it or he was using something else and found that with the 46T he would get more speed.
Have you tried bigger pinions? It's what I usually do when I need more speed. Right now I have a 17T and if I want more speed I can just add a from 18-30T pinions. For more speed you would need a smaller spur and/or bigger pinions, but keep in mind you will also increase the amount of AMPs.
