Higher mAh = More Top Speed -
04.11.2008, 03:59 AM
On Traxxas website they say that with the VXL if you use a 4000mAh you hit 65+mph but if you use 8000mah you hit 70+. Wouldn't they be the same just the 8000mah have more run time
Think of it in terms of power. Power = voltage x current. The faster you go, the more power is required. As tashpop said, a pack with a higher capacity and with the same "C" rating will be able to deliver more current at the same voltage drop as a lower capacity pack, which gives more power.
