Question to the EVO builders!
R00ST
Question to the EVO builders! - 09.15.2005, 01:52 PM
A friend of mine and myself bought two revos to make into EVO's using Emaxx trannies (thx again dafni, ur idea looks like it has spawned many-a-evo's!)
I opened up the tranny area a bit and now can at least fit the E tranny inside, but I am wondering about the driveshafts. The revo shafts seem to rub right now, stokc sized maxx shafts work, but I would prefer the larger/sealed revo shafts. Do you evo builders run the stock ones ok? I could open the part in the front where they are rubbing a bit, or try to mount the tranny more to the one side (so less of an angle on driveline, as I havnt drilled mounting holes for the tranny yet).
also, has anyone found a good method for mounting up batts? I would really like to use a battery cup to give the battery the most support.
