7XL Gears
Nick
COOKIES!
Nick's Avatar
7XL Gears - 09.26.2005, 04:51 PM
Does the 7XL require a certain pinion type, or can any general 540 size pinion fit?
coolhandcountry
coolhandcountry's Avatar
09.26.2005, 05:18 PM
It takes a 5 mm shaft size pinion.
Nick
COOKIES!
Nick's Avatar
09.27.2005, 04:49 PM
Thanks, my next question is.
What gearing would you reccomend the 7XL for 14 cells? Is the stock strobe sliper alright to use?
~ Nick.
Dafni
Dafni's Avatar
09.27.2005, 04:52 PM
For stock wheels and diffs, try a 14 or 16t.
(funny, I just wrote this somewhere else. Deja vu)
Nick
COOKIES!
Nick's Avatar
09.27.2005, 05:06 PM
Wow, you lost me, lol.
I will be using Maximizer/Robinson gears.
So a 14t 5mm pinion and stock spur?
~ Nick.
Dafni
Dafni's Avatar
09.27.2005, 05:14 PM
Oh, sorry, I thought you said strobe slipper (which uses mod1 spurs)
As for stock 32pitch, I use 18/66 or 20/66.
coolhandcountry
09.27.2005, 06:09 PM
If you running the stock diffs. Running the strobe slipper with 51 tooth spur use a 14-16 tooth pinion. If running the 32 pitch gears run the 18-20 tooth with 66 spur.
Nick
COOKIES!
Nick's Avatar
09.28.2005, 03:10 AM
So 18/66 or 20/66 gearing, yes?
nitrostarter
nitrostarter's Avatar
09.28.2005, 01:53 PM
Maximizer/Robinson are the diffs. They use stock gear ratio. Where as if you were to use UE's diffs, the gear ration would be different and you would have to gear for it.
You said something about using the strobe slipper.
The Strobe is way better than stock especially in a higher HP motor like the 7XL. Only set back is that you have to use the 51T mod 1 spur gear and you have to use mod 1 pinions.
N. Rustler conversion
cabking
10.01.2005, 06:24 PM
Its no setback really as Mike has all the pinion sizes in stock most of the time.
Do your self a favour Nick and get the Strobe, Mod 1 is the way to go
Nick
COOKIES!
Nick's Avatar
10.01.2005, 06:38 PM
Whats the benefits of a strobe and mod 1 pinions?
~ Nick.
cabking
10.01.2005, 06:43 PM
Mod 1 is stronger, more material, bigger teeth.
And the strobe+ the Sprong is about the best slipper out there.
It was designed to take the power of the big block nitros, you can actually dial some slip in without the whole thing melting.
Nick
COOKIES!
Nick's Avatar
10.01.2005, 07:11 PM
Why would a stobe slipper effect the pinion type? Or can you get Mod1 Spurs?
~ Nick.
cabking
10.01.2005, 07:20 PM
the Strobe only takes the Ofna 51 tooth spur and that is Mod1 pitch.
cabking
10.01.2005, 07:26 PM
READ ALL ABOUT IT ;)
