Originally posted by coolhandcountry
that is a light weight truck. If the motor don't over wind would be the question. 9 cell is 10.8 volts x the kv which not sure of. 6000 kv would only turn 66000 rpm. If you try it keep a close eye on temps. I ran a 8l on 18 cells. Not sure if it was safe either but still running the motor today. 3000 kv motor on 21.6 volts 64800 rpm.
//Offtopic
Isn't the 8L for around 12 cells? :eek:
How did it perform, did it get hot? Low gearing I imagine too. :D
