I was just trying to figure your motor speed based on voltage drop and looks like you are figure 3.15v per cell to get 63000rpm with that motor and batteries.
What kv are you figuring for the motor?It's rated 4800 non loaded I figure loaded it's more like 4400.The new pro is rated at 5000kv,but I bet it's more like 4500 loaded.
I would be very hesitant to run that setup on quality 4S cells as you'll have some serious speed going there.
Well since in the end your cells dictate your speed,and this is 1 of the highest speed I've seen out of a hv in a mt like this,I have to say I have quality cells.They just don't cost alot.
I clocked my 3905 at 47.2 with 15/68 gearing on 3s. I run HPI tires which I think are a little taller and definitely ballon more than stock. I'm limited to 3s because I run a VXL esc. I was using a Garmin GPS to check speeds. My temps are never over 130 on the motor but the does esc like to run 190 - 200.
Are you saying thats on a 4.5 motor?Because I don't think it would do it.
