Closed Thread
LOSI releases new line of 1/8th scale bl systems! (8.28.08)
edep345
LOSI releases new line of 1/8th scale bl systems! (8.28.08) - 08.28.2008, 07:15 PM
I apologize if this has already been posted, but here it is! :
http://www.losi.com/Search/Default.a...1/8_Sensorless
1300kv OR 1700kv OR 2100kv
- Powerful four pole, high-speed 720-sized brushless motor
- Minimal motor maintenance required
- Precision motor ball bearings for smoother operation
- Sintered Neodymium rotor
- Longer run times
ESC Features - 160A continuous current with 800A peak
- Features the Losi EC5 power connector pre-wired
- High-speed cooling fan for lower running temperatures and protection
- Optimized for Spektrum or legacy radio systems
- Programmable via Quick Program Card or PC Software Included
- Internal and programmable BEC
- Adjustable low voltage cutoff to protect your battery investment
- Forward/Brake with Reverse or Forward/Brake settings
- Forward and Reverse Throttle limiting available
- Four LED's to indicate functions
- Three preset drive profiles: 3S, 4S and 5S
- Two user-set drive profiles
Photobucket
Photobucket
jnev
jnev's Avatar
08.28.2008, 07:22 PM
Already posted. Too late... There is also a RTR 8ight with this system already installed in to it.
jhautz
jhautz's Avatar
http://www.rc-monster.com/forum/showthread.php?t=14402
Here is the thread on it.
to make it...
or break it...
Silent...But Deadly
david lamontagn
08.28.2008, 09:38 PM
5s li-po max................just too bad
MetalMan
MetalMan's Avatar
08.28.2008, 09:44 PM
Thread closed to keep discussion in the other thread jhautz provided the link to.
Closed Thread
