Pinion problems.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
Pinion problems. - 08.20.2008, 12:32 AM
So- I have this project.
For this project I need a pinion. This pinion needs to have 12 teeth, be 32 pitch, and have a 6 millimeter bore. It seems that the problem is that 6mm bore. Where can I get "hybrid" pinions; SAE pitch with a Metric bore?
I've already checked SDP-SI. I don't see them on RC-M. Could Mike make a custom pinion?
MetalMan
MetalMan's Avatar
08.20.2008, 12:47 AM
If Mike can't do it, I think you might be able to get SDP-SI to do it for you. It would require contacting them and getting a quote, of course.
Five-oh-joe
08.20.2008, 12:56 AM
If Mike or that other place cannot do it, maybe give kershaw designs a shot. They tend to have odd pinions (some of which are not listed).
I can't imagine why Mike wouldn't be able to bore out a pinion though (if I remember right, he has a whole CNC dealy set up, right- including drill press?).
08.20.2008, 12:57 AM
This may or may not be of use-
Kershaw sells a 15t 32p 6mm pinion.
www.kershawdesigns.com
What's_nitro?
08.20.2008, 01:02 AM
Thanks guys. I'll shoot Mike an email.
BL_RV0, it has to be a 12T pinion because it's part of a planetary gearbox.
bl-is-future
bl-is-future's Avatar
08.20.2008, 09:00 AM
if i remember correctly some else seen the 15t and needed smaller and he gave kershaw a call and they had them smaller.
What's_nitro?
08.20.2008, 03:45 PM
Ok, thanks. I'll try them, too.
08.20.2008, 04:00 PM
Can't you drill out a 5mm?
What's_nitro?
08.20.2008, 04:02 PM
I probably could, except I don't have any 32P gears at all. I don't have a 6mm drill bit either. I figure once I bought both of those I may as well have bought one that was RTR.
