Anyone know where to get helical cut........ -
09.21.2008, 03:55 PM
Anyone know where to get helical/spiral cut ring and pinion gears for the E-Maxx? I just want some helical/spiral cut ring and pinion gears with the same tooth count or same ratio as the stock ring and pinion. Thanks for any help.
You can buy hotbodies spiral cut ring and pinion gears for 1/8 diffs, but they have a different tooth count compared to the stock emaxx items- different sizes.
Thanks! I might just get aluminum diff cases and aluminum diff retainer ring, shouldn't have anymore problems with stripping the ring and pinion gears then.
