How To Drill Hardened steel -
10.09.2008, 08:32 PM
to do the jato pin mod on my revo tranny, i have to drill hardened steel, what kind of drill bit will work?
i've broken many bits titanium bits in fact
what the deely yo
thanks
cooling agent, its an oil correct? or just spray with water?
anyone know what size bit i need for the jato pin mod, i was able to drill one shaft easily but i gave up on the other shaft(that was hardened), but now i break the pin every other run (on the shaft i did not mod)and forgot the perfect size of bit..... DOH!!!
thank you thank you
Cooling agent...such as Cool tool. I work w/steel and drill often and a cooling agent is key when drilling hardened steel...it keeps the bit cool.
we need a "has this answer already been posted thread" i searched for "tranny mod revo" and came up with too much to search thru, again brian you have nailed it thanks,
you the man
please delete this post
lol, that's ok. There are a lot of posts to sift through in that thread, so I can understand. But, I recently added a link to the pin mod in the initial post...
Something to think about though, the harder pins might not necessarily be the best choice. harder is often more brittle, and could cause snappage easily.
Not saying its for sure (different alloys can be harder and stronger) but if you use the harder ones and keep snapping them, no harm in trying the others.
For the hardened shafts, I found that using two modded pins works better. It seems they always break near where the smooth part of the pin meets the threads, so that tells me there is more stress there. So, I shortened two pins and threaded them from each side. Not only does this spread the stress across two pins, if one/both break, the threaded part captures them and you don't have broken pieces floating around the tranny. Worked for me for a long time, and is still working AFAIK (RCM member krunk bought my revo a while back).
lol i was just slow on my post, i was writing as you answered my question, so when i posted it, your answered was already up making my post pointless. damn this site for having knowledgeable people ready to help with the quickness:)
thank you
