Brushless help
bb16
Brushless help - 10.07.2008, 08:29 PM
Hey all,
I need some help with my brushless system. The problem is that the motor will not turn at all most of the time but randomly it does work when I start the system up, and when it does work it will sometimes work at near full power but other times it will have very little power.
The truck has been sitting around for a few months waiting for some parts but before I put it away it worked fine. The only thing I changed was I put a rc monster 2 speed adapter on.
I have the motor and esc from the fine design lst conversion kit and a max amps battery (BK Warrior 100amp 20 cell esc I think and the Fine Design equivalent to the feigao 9xl) . I have tried using a different battery but it still does not work and the drive terrain of the truck is free moving.
Thanks for the help.
brushlessboy16
brushlessboy16's Avatar
10.07.2008, 08:42 PM
sounds like either
A. needs to be recalibrated
B.Esc might be on its way out
Maxamps, finedesign- not exactly the best combo
bb16
10.07.2008, 08:53 PM
Ya I know but I got the esc, motor, and mounts for $180, Im also testing with 3s Flightpower batteries. The esc did require some work though soldering surface mounts.
brushlessboy16
10.07.2008, 08:54 PM
10.07.2008, 08:57 PM
Check all of you solder joints between the esc and motor. Give them a good tug, and check the conectors (if you have any) for corrosion. And recalibrate the radio.
plaviblue
plaviblue's Avatar
10.07.2008, 09:09 PM
Hey guys, how do tell if you have a bad brushless motor?
FLM Extended Savage -Nue 1521 2d MMMv3 6cell
E-Maxx -Flm Parts stock motors (the wife's)
Slash -MM medusa 3300k 3cell 68 mph!
[B]Custom FLM Axial Crawler
Losi Rammunition 1/184600k
JaySki
JaySki's Avatar
10.07.2008, 09:15 PM
It won;t work.
10.07.2008, 10:03 PM
Originally Posted by JaySki View Post
It won;t work.
Wow, I am stupefied by your genius...
A bunch ofcogging, and very quick heating of both the motor and esc usually signify a bad motor, or bad contacts.
bb16
10.07.2008, 10:25 PM
Sounds like the problem i had, contacts between the motor and esc seem fine, time to check the internal connections I guess.
brushlessboy16
10.07.2008, 10:30 PM
check shorts between windings, between can and winding, or if your rotor de-magged
bb16
10.07.2008, 11:27 PM
Well it looks like it is the esc, the esc was unable to power my castle creations motor while the mamba max was able to power the fiegao motor. Can anyone recommend a good esc for a 4 cell fiegao 9xl setup on an LST?
10.07.2008, 11:33 PM
MM with a fan, and a few extra caps. The lst is heavy, but you are running a 2 speed and mech brakes? Should be ok that way.
A MM with an ubec, fan and extra cap... or I have an opto BK9920 if you want...
plaviblue
plaviblue's Avatar
10.08.2008, 08:14 PM
I was noticing my motor was getting really hot with not much use, could a bad motor take out an ESC?
brushlessboy16
10.08.2008, 08:23 PM
yes it can, better check it before you wreck it lol
