Source for 5mm bore 48P pinions?
skellyo
skellyo's Avatar
Source for 5mm bore 48P pinions? - 10.23.2008, 04:57 PM
I have only found one source for this style pinion, Kershaw Designs. Their price is quite high at $20ea. Does anyone have another source?
The other option I'm contemplating is buying a pinion from sdp-si that has a bore of about 4.75mm and just hitting it with a 5mm bit on my drill press.
Any info on if someone has done this sort of thing would be appreciated.
Also, FWIW, this is to install a 1509/1Y into a T4 that is going to be converted into a J82. I plan to run 2S primarily, but probably will hit it with 3S for some speed runs or stupid fast bashing.
brushlessboy16
brushlessboy16's Avatar
10.23.2008, 05:22 PM
I beleive one of the crawler stores sell them IIRC, i will look for ya'
edit- http://www.rc4wdealer.com/index.php?...ain_page=index
skellyo
skellyo's Avatar
10.23.2008, 05:24 PM
Yep, seen that already. I should have clarified...22T and larger.
brushlessboy16
10.23.2008, 05:25 PM
why not convert to 32p?
skellyo
skellyo's Avatar
10.23.2008, 05:29 PM
Because I don't know of a 32P spur that will fit on the T4 slipper clutch.
MetalMan
MetalMan's Avatar
10.23.2008, 09:36 PM
GT2?
http://www3.towerhobbies.com/cgi-bin...spur&search=Go
skellyo
skellyo's Avatar
10.23.2008, 11:03 PM
Originally Posted by MetalMan View Post
That looks like it just may work. I didn't realize they changed the slipper style on the GT2. I'll have to order one and check it out. Thanks!
hoober
10.24.2008, 03:27 PM
If Pete is still in business http://www.modelelectronicscorp.com/...ucts.php?tid=7
I've ordered two batches of 48 pitch x 5mm online.
