Brushless Associated Mini-MGT 3.0 - StampedeProject.com
stampedeproject
stampedeproject's Avatar
Brushless Associated Mini-MGT 3.0 - StampedeProject.com - 10.18.2008, 03:47 PM
Yeah, OK, OK, I know I have a serious freaking problem. Why in the name of everything holey in RC do I insist on converting perfectly good RC's to brushless? Honestly it happens innocently enough. One minute I am cleaning my Mini-MGT and then next I have the clutch pulled off to "just take a look" at what it would take to convert it to brushless. I swear that I must have blacked out, because the next thing I know the clutch has been converted to single speed, locked, reassembled, and I am Dremeling my way through the uni-constructed electrics mount to free the servo mount. As well all know... modification is the point of no return.
As much as I love my converted brushless Revo (Revo'Lution), a littler/smaller brother Imgp7878.jpg (344467 bytes)sounded like fun. Also I have never seen a brushless Mini-MGT, so I thought it would be unique. This little rig was just begging to go brushless and the conversion is very easy if you have the skills to make a motor mount. My only regret is that the Mini-MGT was such a good little Nitro RC with a lot of stock Nitro centric features such as reverse, 2-speed transmission, and even a 4-channel radio all beautifully packed, typical Associated style, into the chassis which simply are not needed after the brushlessImgp7871.jpg (492392 bytes) conversion. Ohh well, 1lb of crap gone that isn't needed.
As noted, it all started with yanking the 2-speed spur gears and locking the clutch by simply screwing a 4mm screw into the clutch adjustment hole, reassemble the spur gear parts but omitting the larger 1st gear - done and I still have a working slipper clutch.
Imgp7873.jpg (397715 bytes)The motor mount plate was made with 1/4" 6061 aluminum. I simply traced one of my RC-Monster motor mounts to assure the hole/slot positions were right and tossed the ruff cut plate into my Proxxon Mini-Mill and cut the slots, milled an inset to lighten the plate, and then finished all the edges. The little Proxxon mini-mill isn't fast but it does do a very nice job. Once I had the plate milled, I did a little finishing with a sander and the motor mount was ready for mounting. A good rule is to drill the chassis holes first then mark and drill the holes in the part to be attached to the chassis last. I drilled the chassis holes, marked the hole positions on the plate and drilled a couple holes with the drill bit that came Imgp7867.jpg (461687 bytes)with my 3mm tap set. Rub a little wax on the tap for lubrication, tap the hole, and the mount is ready to be attached to the chassis.
The pictured plastic battery tray/mount was actually a Wheely King battery box half that is screwed to the stock trimmed throttle/brake servo posts on one side and a spacer on the other. I will eventually make nice aluminum tray like I made from my Menace, but I wanted to do some testing before I got too far ahead of myself.
Double stick tape the ESC and RX in place, mount the HUGE Neu 1512/2.5D and by simply adding a MaxAmps 3S pack we are ready to bash brushless style.
As far as speed the Brushless Mini-MGT is faster than Imgp7874.jpg (406610 bytes)the nitro version on 3S, on 4S it's just insane. The really interesting thing here is that I don't even have a fan on the Mamba Max and after 30 minutes of bashing and testing, neither the ESC or motor was hot. This size Neu is a bit much for this very light little 1/10th scale rig. Currently I am running a 540 sized 50mm length Medusa Product 2000KV motor that seems to do just fine lofting the wheels and gives me a bit more runtime due to it's smaller size.
Overall I am very happy with the conversion. The only little glitch was that I had simply detached the reversing lever from the removed servo and on hard hits it would flip the transmission into reverse - made it kind of fun and un-predictable to drive. I used a short link and fixed the lever in place. I may will also do a little cutting on the chassis at some point to rid the superfluous metal extensions required for Nitro mounting, but for now this is a very fun, fast and durable little basher.
10.18.2008, 03:59 PM
Very nice. Did you use your Proxxon mill to make the mount?
stampedeproject
10.18.2008, 04:31 PM
You bet I did.
10.18.2008, 04:42 PM
Nice. I'm getting one in a week or two!
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
10.18.2008, 06:25 PM
Nice work, im surprised that there isn't alot more people converting the Mini-MGT
10.18.2008, 06:28 PM
Looks like a good alternative to the LST if someone wants something a bit smaller. Or a better alternative to the e-savage maybe?
10.18.2008, 11:13 PM
Nice conversion. I like the front battery tray placement. I try to do that with most of my conversions, as it helps steering and makes wheelies more controllable.
stampedeproject
10.20.2008, 11:53 AM
Video of a little testing
http://www.youtube.com/watch?v=dt1c73IAknE
rschoi_75
Certified Spaceball
rschoi_75's Avatar
10.20.2008, 12:52 PM
looks like a blast! Nice build.
rcm xt8
rcm xb8
rcm crt.5
10.20.2008, 09:56 PM
Wow...That thing must rip!
stampedeproject
10.23.2008, 10:54 AM
I am toying around with selling this Mini-MGT... I have too many RC's and according to my wife, I need to find new homes for a couple RCs and she doesn't care as long as it's someone else's home. ;)
If I sold, it it would include the full rolling chassis, body, the steering servo, but not the battery, ESC, RX, or the Neu motor. Basically you would get the rolling chassis ready to bolt up a motor, ESC, drop in a receiver and pack and you would be ready to bash. The used Mini-MGTs on ebay are going for the $250 range.
Anyone interested enough to make me an offer?
