Originally Posted by DRIFT_BUGGY
I have had a few people tell me that the D wind motors should be run on Low timing and the Y Med-High and others have said that it is best for 4-pole motors to run on Med-High. Anyone had expereince in running different timing with 4-pole motors?
From what I understand, being Delta wound or Wye Wound doesn't make any difference as far as timing goes.
However, the number of poles a motor has does make a difference.
2 Pole motors usually can only tolerate Low-Med timing.
Where as, a 12 pole outrunner likes to be run on High Timing.
I've always ran the highest timing a motor would tolerate and let temperatures be your guide.
If your timing is too high, it will run Hot and needs less timing.
I'm running a Medusa 36-60-1500kv in an E Revo with 18/40 gearing on 6S. It's timing is set to High and does just fine. However, I do have a fan/heat sink on the motor.
The Medusa is a 4 Pole motor. I hope this helps.
