CC 6.5mm bullets vs 4mm bullets
shizzon
shizzon's Avatar
CC 6.5mm bullets vs 4mm bullets - 12.02.2008, 02:50 PM
Will i see any noticeable gains by replacing the 4mm bullets that came on my teckno Neu to 6.5mm CC ones? I figured that since the 4mm ones came on the motor they should be enough but if it is advantageous to use the larger ones then i will most likely switch them out eventually.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
12.02.2008, 07:02 PM
It won't kill anything to run them, but if you find they heat up during a run you should replace them with 6.5mm bullets.
Area 52 Ranch Raceway
T.R.C.R.
