lst, lst2,aftershock brushless conversion
mikeproject1
lst, lst2,aftershock brushless conversion - 12.04.2008, 02:35 PM
im lookin for sombody that either has or can made a 2 gear pinion gear for a bruchless motor shaft for my lst. im converting it to electric and im going with the mamba monster. plz help
12.04.2008, 02:44 PM
Use this:http://www.rc-monster.com/proddetail...rcm2spdadapter
You can use the stock removeable pinion gears from the lst 2 on it. Or the rcm store has the gears as well. Some of the lst clutchbells do not have removable gears.
Byte
12.04.2008, 05:02 PM
One problem, since someone else bought that thing, a few weeks ago they are out of stock.. :(
So does somebody else knows something maybe?
Thanks,
Patrick
Pinion Options
Bad Karma
Pinion Options - 12.04.2008, 07:46 PM
Info here - Colleted Adapter info
Available here - Colleted adapter
He makes high quality parts and it will not require you to grind a flat spot on the motor shaft, he also makes a one speed so you can use motor brakes and reverse, and just released a motor mount and I'm currently waiting on one atm
gogglespaesano
gogglespaesano's Avatar
12.04.2008, 09:34 PM
+1 on bad karma's recommendation. I use his stuff and it is top notch.
12.04.2008, 09:38 PM
His one speed adapter is great, plus you can run std hardened pinions and use motor brakes. I run the single speed adapter, 59/23 gearing with the FOC in the tranny with the gears swapped for a slightly lower ratio. Motor is a hacker c50 11xl (1500kv) on 6s lipo thru a MMM. Very good setup and the MMM has no trouble flipping the truck on its lid under full brakes. Plus getting rid of the shift and brake servos make some room for a forward battery tray, which greatly helps weight distribution. My lst is almost as nimble as my erevo because of this.
