Speed Pede Project...
Speed Pede Project... - 11.01.2008, 09:41 PM
Well my pede hasn't had much attention lately so I gave it a bit of a make over...
I think the motor (CC 1515 1Y 2200) is overkill but needed to run it in something - I can't get a MMM in there though as the motor wires aren't long enough so opted for a trusty MM.
I inverted the RPM bumper and added some lead to help keep the front end down. I think I may have to lose the wing but will see what happens... I checked and it looks like a revo 2.5 body that I have will fit pretty well if I lose the wing...
Any other suggestions?
Differential Ratio: 1
Transmission Ratio: 2.727272727272727
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 20
Total Voltage: 18.5
Motor KV: 2200
Tire Diameter (inches): 4.1
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2 : 1
Total Ratio: 5.45455 : 1
Tire Circumference (inches): 12.88 inches (327.17 mm)
Total Motor Speed: 40700 RPM
Vehicle Speed: 91.01 mph (146.2 km/h)
Estimated Adjusted Speed: 79 mph (127 km/h) - 13% loss
Effective KV Value: 2200
11.01.2008, 10:49 PM
That has got to be the coolest pede I've ever seen.
You should opt for a rustler chassis in favour of the pede one.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.01.2008, 10:54 PM
Have plenty of spare parts on hand! 80 MPH crashes are not pretty!
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
11.02.2008, 12:13 AM
Sweet Pede, what motor mount is that?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
MetalMan
MetalMan's Avatar
11.02.2008, 12:20 AM
That's the FLM tranny case.
Looks great! I like the wing on there.
DRIFT_BUGGY
11.02.2008, 12:52 AM
Does it work with a Bandit to?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
jnev
jnev's Avatar
11.02.2008, 01:02 AM
I can't see why it wouldn't work with the bandit. If the rear end of it is the same as a rustler and Stampede, it will work just fine.
11.02.2008, 10:06 AM
The wing in from an OFNA LX - just shorten the centre posts a little.
The motor is a Castle Creations 1515 1Y
TheRandom1
11.02.2008, 11:17 AM
That makes me almost wish I hadn't gotten rid of my Pede a few months ago...
  Send a message via Yahoo to TheRandom1 Send a message via AIM to TheRandom1 Send a message via MSN to TheRandom1
trev3813
Dsm needed
trev3813's Avatar
11.02.2008, 12:52 PM
Nice PEDE
11.02.2008, 02:53 PM
Chassis looks interesting, is it the thunder tech chassis? I have a g10 chassis that looks alot like it, with the bell crank steering, from thunder tech.
11.02.2008, 03:52 PM
I think it is an Xtreme Racing chassis... I ran on 4S and clocked an easy 55... However I broke the diff internals so need to order some more... :(
I really need to find somewhere flat and a radar gun - The GPS really needs a lot of space to get an accurate reading...
PS the shock setup is sweet though...
Takedown
WARNING: May become violent.
Takedown's Avatar
11.02.2008, 04:10 PM
Nice pede. Now that you posted a pic of your CC 1515, Ben can aswell...
RIP- Tammy (9/14/08)
11.02.2008, 04:25 PM
I thought he had already which is why I posted mine...
brushlessboy16
brushlessboy16's Avatar
11.02.2008, 05:30 PM
Little bit late there ryan?
My Motor thread- started October 16th.
