I have a 3PM, I wanted to use it in my CRT.5. I hooked everything up and the steering servo would not work. (I though I had a bed receiver) so I got a new receive and I am having the same problem. Channel 1 on both receives do not work. I am using a new servo and a RX pack to do the testing. When I hook the servo to channel 2 or 3 it works fine (with each receiver) but channel 1 won’t work. I check all the setting on the radio and they are good.
I havent ever heard of that one, but I suppose anything is possible.
I dont know if that radio has channel mixing on it or not, but if it does you could possibly mix the steering channel and the Aux channel and plug the servo into the Aux channel. It should work for a short term work around untill you can get it fixed or replaced.
to make it...
or break it...
Is the ch 1 on in the radio....some radios allow you to turn off channels
