E-maxx driveshafts, need stronger ones -
01.03.2009, 08:06 PM
I'm curently running style sliders and one my battery's second charge, i had one to brake. So i'm looking for some CVD's or dogbones that won't break to put in my maxx. Are thair any good ones i can get for a decent price? And were would i buy them?
Thanks for all the help!
NeuMaxx
01.03.2009, 08:14 PM
You could try some cvds, but people have posted that they can break and bend. I have a setup similar to yours and am still using Traxxas sliders. I have not broke mine yet but if I do the are very cheap to replace. I also like them because allow a little "give" in my drive train.
01.03.2009, 08:17 PM
for stock maxx - traxxas ones - 5151R are quite nice. tower has them
or get from mike 4x drive cups and dogbones
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
01.03.2009, 08:23 PM
NeuMaxx
01.03.2009, 08:28 PM
Personally I don't like the MIP cvds because the cup pin can spin out. I like cvds that have a retaining ring.
A Horse's Ass
01.03.2009, 08:35 PM
I've tried the 5151R Traxxas ones. Bent one right off the bat and since have had two of the stub axles snap off. The other 2 have held up and are still on the right side of the evo got stockers on the left side. Not real cheap fixing them when something goes wrong. I think it was $12 for a new shaft and the stub axles are $7 each. Haven't tried any other cvd for the maxx/revo that I can speak badly of. I'm a believer in the stock sliders and just replace when they were out or break. They usually sell in units of 4 complete shafts on ebay for a good price.
RC-Monster RC8T
01.03.2009, 08:44 PM
Stock sliders generally hold up well. Try loosening your slipper a little
Brushless only!
01.03.2009, 11:02 PM
With a powerful brushless a slipper doesnt solve the problem. I tried a few cvds and broke them running on 4s with a loose slipper. The only ones that has held up to locked slipper 6s lipo abuse is the mip 1665 cvds(was trying to see if the cvds would hold up, I broke 4 diffs, 2 sets of center shafts, and the tranny trying to see if the mips would hold and they did). They are expensive but worth every penny. I dont care or the cvd pin but when you put the cvds together dremal a flat spot in the pin and locktite the set screw down in the flat spot and they will not come apart.
01.03.2009, 11:43 PM
WOW! You'r the first person that i've heard of talking good about mip. lol Before now all i've heard was bad things
E-Maxx Lover
01.04.2009, 12:31 AM
Same here its hold up but I did not dremal a flat spot I just put duratrax threadlocker :)
MMM v1 zippy 2x3s 5000mah neu 1y 1/8 diff's
MMM v3 Rc-monster 2x2s 5200mah-HC medusa 36-70-2300kv
Pic's - video - youtube video's
01.04.2009, 02:35 AM
im running the 1.5d on 4s and after upgrading to center CVDs only and 17mm, i havent had a problem yet!
JERRY2KONE SUPERMAXX
Another Option. -
01.04.2009, 06:03 AM
There is another option you may consider, but it is not the cheapest way to go. You can buy the Traxxas stub shafts, and remove the plastic couplers(Dremel), and the pin(punch or press). Then install the stub shaft and put a heavy duty coupler on the inside of the knuckle. Finally have RCAlloys make up a set of custom dogbones just for your setup($20 a piece). You can even specify the dimenssions you wish for length diameter, and pin size. I am working on this setup myself right now for one of my Maxx projects. The axles will be 8 to 10 mm in diameter for extra strength.
I cannot tell you what length to get, because I am also extending my arms by 12mm for extra stability and handling at high speeds, so my dogbones will be very long. I can pretty much assure you though that this setup will not break. If anything you may break the stub shafts under some real heavy duty bashing, but they run like ten bucks a set, for 4 of them at T/H.
You also have the option of purchasing RCM stub shaft adapters for mounting up 17mm hex adapters. These work perfectly when using Axial beadlock rims. There are always options to consider, but I always lean toward the heaviest option available to achieve what we call "BulletProof" builds. I hate having to stop playing due to periodic breakage, because of inferior material setup parts. SO there are some other options for you to think about in your quest. Good luck with that.
Supermaxx
01.04.2009, 06:31 AM
Instead of removing the plastic couplers just go to tower and buy them. I made some stub shafts using the revo stub shaft axles:
http://www3.towerhobbies.com/cgi-bin...?&I=LXHFY7&P=7
Just cut off the threaded portion. I don't use them anymore since I'm using UE 8mm cvds so I sold them to a guy in the UK.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
01.04.2009, 09:36 AM
i had MIPs in my pede, they sucked. i know a lot of ppl r eyeing the Summit/BL E-Revo shafts
Check out my FS thread in the General Discussion!! Help me go lipoly!!!
RC-Monster Square Tube
01.04.2009, 10:35 AM
The MT-sized CVDs are much more stout than the Pede/Rustler sized ones- don't use the smaller ones for comparison- I have been using the same CVDs in my Maxx for over 3 years and they have a million miles on them. Just a few days ago I had the pin almost come out on my rear centerdrive- so I went and ground the flat on the middle of the pins on all 6 CVDs and used red loctite on the setscrew. If you do this when you first get them, you'll not have any problems. CVDs do get bent, and straightening them is not a big deal- I've done it numerous times without removing them from the vehicle- just takes practice. Keep them grit-free, and lightly oiled and they'll last a VERY long time.
