2200 Kv or 2650 Kv?
Urgeoner
Urgeoner's Avatar
2200 Kv or 2650 Kv? - 04.13.2009, 09:55 PM
I don't know what to get can someone tell me some differences between them? the 2650 is more for torque apps while the 22oo is more for speed? or the other way around?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.13.2009, 10:21 PM
The difference is that the 2200kv is comparable to a 1515 1Y neu and the 2650kv to a 1512 1y. The 1515 is a longer motor than the 1512, 2200kv is longer than the 2650kv. The 2200kv is more suitable to a Monster truck or Truggy and can be run on 4-6s Lipo. The 2650kv is better suited to a buggy on 4s. If your plan is to put this in a Revo, it is the revo section of the forum, go with the 2200kv. 4s Lipo is more than adequate unless your going for crazy speeds.
Unsullied_Spy
Unsullied_Spy's Avatar
04.13.2009, 10:36 PM
The 2650 will be fine in the Revo with proper gearing and will be more controllable, the 2200 can handle taller gearing and will be more powerful.
Urgeoner
Urgeoner's Avatar
04.13.2009, 10:42 PM
ya it's gonna be a 3.3 conversion. So, I'm thinking...I don't know yet, thanks for the replies though. I know I wanna go quick, but also want plenty low end.
jzemaxx
04.14.2009, 12:01 AM
2200kv......nothing else. Trust me...
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
04.14.2009, 02:22 AM
yeah go with what ^^^^^ said.
i built a revo for my friend using the 2200 combo.
we run 6s but geared it for only 40mph.
so we get UBER cold temps and a resonable speed.
so 6s isnt automaticly as crazy as everyone seems to think,,,just tame it down and it's a much more efficient setup.
shaun
  Send a message via MSN to shaunjohnson
Unsullied_Spy
04.14.2009, 02:40 AM
shaun
It must wheelie like mad on 6s geared for 40 MPH. I had a converted Revo and I ran a 1515 1.5D on 4s with 22/62 gearing and I could wheelie it at about 40 MPH. The 2200 is a good motor for the Revo, but I'd keep it to 4s unless you want to spend a lot of money fixing it (I blew a diff in under an hour on 4s, and it was properly shimmed).
shaunjohnson
i pwn nitro
04.15.2009, 03:44 AM
not at all...
there's this cool thing called "punch control" and "throttle curve"
just tame the power and put it where u want...and you'd never know...and on hte + side...there's power avaliable when u need it (magor correction after a crap jump) and uber cool temps.
and as for blowing diffs...unless you wanna bulletproof your drive terain (w/ RCM 1/8th diffs) thjen drive MMM and revo friendly, dont mash the throttle so hard unless u use punch control.
i have NEVER blown a diff EVER...even on 6s...the only people i see who blow diffs are running 4s and have the punch control as their finger...and they have lead fingers. so go figure
6s is a MUCH better setup IMO but u have to tame it down some to save the car, remember...the benifits of 6s is not only speed...but cool running and reserve power too!!!!
shaun
Urgeoner
Urgeoner's Avatar
04.15.2009, 09:39 PM
Thanks for all the help...what do you guys think about Losi's xcelorin esc and a 2100kv or even a 17kv, compared to the MMM? It can handle up to 5s I believe...
Unsullied_Spy
04.16.2009, 01:41 AM
EVERY Losi BL system I've ever seen or heard about has had issues and their customer service isn't all that great. I haven't heard as much about the 1/8th scale as I have their smaller stuff but I would rather go with a Castle product and know that IF it breaks, you will be covered.
hpitraxx
hpitraxx's Avatar
04.24.2009, 02:46 PM
hi unsullied spy looks like you have used quite a few different motors whcih would u recommend?
Unsullied_Spy
04.25.2009, 05:33 AM
It all depends on what you are putting it in and what kind of power you want. A 2650 in an E-Revo will be plenty powerful and, IMO, better for racing because it'll be more controllable. Sure you can dial down the throttle curve and do a bunch of other fancy tricks to cut back power but an ESC is the most efficient at 100% throttle because that power can bypass the FETs altogether, resulting in a cooler ESC. From what nitrostarter says, I should be making some sense
I ran a 1515 1.5D on 4s lipo in my Revo 3.3 conversion and it would scaree the crap out of a person. It' basically the same motor as the 2200 but higher KV, and it would spin all 4 Talons on ashpalt until they finally hooked up and flipped it (I did get it to backflip a few times, seeing a full-size Revo backflip is exciting but tough on parts). You can't really go wrong with either setup in the E-Revo, it all depends on what you're looking to get out of it.
04.24.2009, 02:57 PM
All depends on the situation - I've pm'd you a guide to read.
hpitraxx
hpitraxx's Avatar
04.24.2009, 03:30 PM
thanks
the 2200kv mmm combo looks good to me
nitrostarter
nitrostarter's Avatar
04.24.2009, 04:01 PM
I ran the MMM 2650 in my 2.5Revo conversion on 3 and 4s geared for about 43mph on both battery setups. I loved it. It ran super cool and had plenty of power and torque for uncontrollable wheelies if I wanted. I have sinced moved this setup to my Jammin X1 buggy and will probably end up getting another 2650 combo to put back in the Revo...
N. Rustler conversion
