How often do you check you bearings?
losi b
How often do you check you bearings? - 03.07.2009, 10:19 PM
I just grenaded the front bearing on my Neu 1512 1.5yf. How often should I check the bearings?
Thanks,
Brian
03.08.2009, 12:52 AM
Honestly, when they grenade. I should and will start being a little more careful about checking due the expensive motors I have
03.08.2009, 12:53 AM
Almost forgot...welcome to the fun house!
Semi Pro
Semi Pro's Avatar
03.08.2009, 03:29 AM
i tare down my motors for cleaning and relube bearings on my motors every couple of runs, but im overly careful with all my motors, not just the bearings
mambarustler
Kiss My Ass NITRO!
mambarustler's Avatar
03.08.2009, 11:06 AM
Any particular lube you use? a link would be nice.
Thanks
E-REVO
Slash 4X4 PE MM/Medusa 3300KV
3PM 2.4Ghz
WANTED: MMM/2200KV COMBO
  Send a message via AIM to mambarustler
Shark413
Shark413's Avatar
03.08.2009, 03:15 PM
You have to be careful regarding the bearings. If they blow out the race the rotor can become loose enough to hit the inner coils which would be bad news. You can grab the end of the shaft/pinion and try to move it, when the bearings wear out you will feel movement, a new bearing or one in good shape should have zero movement.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
Cartwheels
03.09.2009, 10:46 PM
in and out or side to side?
Shark413
Shark413's Avatar
03.10.2009, 02:11 PM
That would be side to side, any movement in this direction could mean the actual balls or races are wearing out. Normally what happens is the bearing gets dry (no oil/grease) or dirty. Then the friction and heat cause the cages (these hold the balls in the proper position) to fail, which leads to major bearing failure. With In and out movement there is a little more play, even if there is movement in this direction when the motor energizes it will self align (center the rotor betwween the coils). Of course you don't want excessive movement here either, but a little is ok.
Semi Pro
Semi Pro's Avatar
03.10.2009, 05:52 AM
Thanks
i have always used trinity preminum bearing lube
