Hyperion EOS0606i CHARGER
Jason
Hyperion EOS0606i CHARGER -
03.14.2009, 01:50 AM
I need to know if I can using a external power supply on this charger instead of using the internal one ?
Jason
Find all posts by Jason
2
azjc
03.14.2009, 01:53 AM
thats what the alligator clips that are connected to the red and black cable are for
azjc
3
Jason
03.14.2009, 01:58 AM
ok I own a power supply the specs are :
13.8 VDC
10A CONSTANT
12A PEAK
do you think it can work without any troubles ?
Jason
4
Jason
03.14.2009, 02:37 AM
ok it work fine but is like the integrated power supply I cant charger a 4s lipo @ 6amps only around 2 , 3amps ... so with the internal or external power supply the charger rest at 50watts max output ?
Jason
Linear Mode
Switch to Threaded Mode
