drivecups
Urgeoner
Urgeoner's Avatar
drivecups - 04.03.2009, 08:31 PM
ok I already posted in the emaxx forum, and now I will post here:
Anybody know where i can get drivecups for center dogbones for a revo convesion that's using a 3905 center diff? I have the v3 hybrid diffs and i can only run this way now, and I need some advice on reasonably priced drivecups and shafts..I've been IMing Mike about them but he's apparently pretty busy and I would like to get up and running because it's been a while now and i havent had a chance to get it running. Someone suggested UE drivecups, so I went on their website and I can't find just the cups...so please help me!!
George16
Supermaxx
George16's Avatar
04.03.2009, 08:56 PM
UE have the 8mm cups in stock.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
04.03.2009, 09:02 PM
Normally, I wouldn't do this, but since he's busy, maybe you can try http://rcalloys.com/
George16
Supermaxx
George16's Avatar
04.03.2009, 09:03 PM
You need 2 of these:
http://www.unlimitedengineering.com/...ore/85038.html
Revo with OS .18TZ
Urgeoner
Urgeoner's Avatar
04.03.2009, 09:06 PM
George16, Thanks dude...what does the 8mm mean? 8mm in circumference? And they fit the transmission right?
BrianG-I am going to check that site out thanks a lot!
George16
Supermaxx
George16's Avatar
04.03.2009, 09:07 PM
8mm is the internal diameter which is what you need for the size of the pinion shaft you have. I have a bunch of them being used on my trucks.
Revo with OS .18TZ
Urgeoner
Urgeoner's Avatar
04.03.2009, 09:09 PM
ok, because Mike told me about 6mm ones that he had in stock; they wouldn't work on the 3905 tranny then right?
George16
Supermaxx
George16's Avatar
04.03.2009, 09:13 PM
I didn't fully read your OP. Yes you need the 6mm cups for the tranny output shaft and 8mm for the pinion in the diffs.
Revo with OS .18TZ
04.03.2009, 09:14 PM
So the 8mm UE cups will fit on the v3 output shafts?
Urgeoner
Urgeoner's Avatar
04.03.2009, 09:15 PM
hmm...wondering if UE has the 6mm ones now...
Urgeoner
Urgeoner's Avatar
04.03.2009, 09:16 PM
yes they do =)
George16
Supermaxx
George16's Avatar
04.03.2009, 09:17 PM
No. The V3 uses a pinion which has a 5mm end(mugen, I believe). The V1 and V2 uses the Hot Bodies diff which have a 8mm pinion shaft. Sorry for the confusion.
Revo with OS .18TZ
Urgeoner
Urgeoner's Avatar
what do the 5mm drivecups fit on? oops^^ my bad
Urgeoner
Urgeoner's Avatar
04.03.2009, 09:19 PM
will the hotbodies diff fit inside the v3? 8mm is stronger than 5mm...
04.03.2009, 09:35 PM
I don't think so....it says that Mugen, Associated and Losi will fit
