Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
V.3 hybrid revo diffs in 3905 emaxx
doo540
V.3 hybrid revo diffs in 3905 emaxx - 04.27.2009, 08:36 AM
Has anyone tried or maybe knows if the V.3 hybrid revo diffs will fit in the 3905 emaxx? I have a set of V3 but forgot to check and see what issues there would be trying to run them in my emaxx.
crazyjr
crazyjr's Avatar
05.21.2009, 09:36 AM
you would need cases specific to the Emaxx, Like UE or the FLM hybrid bulks. I'm sure someone else will chime in on other alternatives
Unsullied_Spy
Unsullied_Spy's Avatar
05.21.2009, 09:56 AM
As far as I know, the best way to get tough diffs for the Maxx is to cut away a little bit of the bulkheads and get some LST diffs for it. You'll have a hard time stripping a well-shimmed LST diff.
doo540
05.21.2009, 08:16 PM
Hmm, I just took out 2 lst2 diffs in my lst2, 1515 2.5d on 6s with 23 pinion and 64 spur and stock lst2 tires. I purchased the truck as a used roller added all the brushless stuff and broke the two diffs, (tooth broke of pinion gears). The diffs were smooth when I received the truck, so I didn't open them up. My mistake I guess.
U E Diff Cases
medusa'd maxx
Brushless Basher
U E Diff Cases - 05.22.2009, 07:52 AM
I've just fitted UE diff cases with ofna six spider buggy diffs to my Emaxx 3905
they fit up perfectly with no shimming (in my case) and seem very tough - I used to detroy maxx spider gears every few packs even with maximiser cups and flm combo bulks Neil has been using them with hot bodies diffs and I havent heard that he's had any problems Im running 6s with a 1600Kv 80mm Medusa and loving it - you will have to gear up or pick a higher kv motor like the castle 2200kv
 Send a message via ICQ to medusa'd maxx
