Caster Fusion EX1
cheesecake
Caster Fusion EX1 - 01.16.2009, 02:20 AM
This Thread is for the caster fusion ex1 questions tips and tricks
Heres the buggy fresh out of the box
10 minutes after i opened the box started the teardown for the rebuild.
Started getting everything together.
more pictures of getting it together and electronics installed.
Finally together and ready to go
cheesecake
01.16.2009, 02:28 AM
cheesecake
01.16.2009, 02:34 AM
http://www.casterracingusa.com/forum...ead.php?t=1050
RC Pro and Caster Racing USA have temporarily joined forces to help kick off the new 1/8 electric 2009 season with a bang!
Since Caster is currently the only true electric buggy and truggy manufacturer on the market, yet are unrecognized, they offered to do a great promo that will help RC Pro and YOU!"
Caster Racing has announced that they created a promo sku for their cart that will take the Fusion race roller all the way down to $250. This is a $100 savings!! What a great way to enter the 1/8 scale electric races. This is an assembled buggy just add radio gear, speed control, motor, servo and batteries! This gives you the freedom to choose the electronics YOU want!
OR for those who want to step up to the Pro Fusion instead of the Race Roller the code will give you a $50 discount off the Pro.
Now you are probably asking yourself how this benefits RC Pro. RC Pro has decided that with proof of purchase, a person can receive a free RC Pro membership. That is right. On top of getting the fusion discounted, with proof of entry, Caster Racing will pay your RC Pro membership or membership renewal at your 1st event of 2009 ( a $20 value) as long as the buggy was purchased through Caster Racing USA.
To take advantage of this special send an email to the following and receive a code for ordering either the Race Roller or Pro on the Caster USA website. specials@rcprosites.com
Please specify which product you are interested in.
Rnemhrd
Rnemhrd's Avatar
01.16.2009, 10:41 AM
Looks good. Everything is nice and tight close to the center.
bdebde
That's All Folks!
bdebde's Avatar
01.16.2009, 10:27 PM
Looks nice. How is the front to rear weight balance on those. The batteries look awful far back to me.
cheesecake
01.17.2009, 01:58 AM
front to rear balance is about even i was expecting it to be really back heavy but its not. they did a good job designing the car and laying everything out.
himalaya
himalaya's Avatar
02.04.2009, 02:35 AM
cheesecake how do you think about the Losi motor ? any good? power, efficiency, heating up......
....What a Blue Sky....
Maggot
03.10.2009, 04:15 PM
Hi all,
I have an early EX running MMM with a 1512 2.5d/f, standard 44/13 gearing, and a pair of 2s 5000 20c continuous 30c burst. I haven't run this much but I'm questioning my Speedo settings. I have read the "MMM what's your settings" thread and gone for 80% punch control, low start, normal timing 10deg. Though I have only run this in the street, neither the motor or speedo get hot. I have 45degC on the motor and then same on the speedo. The cells don't seem to alter. Ambient is about 8C. The torque seems . The top speed doesn't seem to be all that.
What is your advice?
Gear it up? Advance it?
I'm new to all this electric RC stuff so all advice accepted.
BTW nice Forum and interesting products on the shop site.
MetalMan
MetalMan's Avatar
03.10.2009, 05:21 PM
Gear it up! That motor can handle quite a bit more, maybe up to a 16t pinion in your setup. For starters you may want to consider a 15t, though, just to be on the safe side.
03.10.2009, 05:35 PM
Just double checking you are running the batteries in series right....
Maggot
03.11.2009, 03:22 AM
Arct1k, Yeah! I'm running them in series.
Metal Man, Thats the way I was thinking. I just wanted input as the kit I need over here in England is rare and importing stuff, these days, is very dear. Not just because of the exchange rate but carriers like to change us for doing the customs paper work as well.
Thanks for the input guys I'll let you all know how it goes.
Cain
03.11.2009, 04:18 PM
From what I have heard Neu Motors saying is that the Neu line runs better with a low or lowest timing setting.
As for your speed, how are you confirming its not up to snuff? Is this confirmed on your track going down the longest straight? if so, gear up so you top out towards the end of the longest straight. I usually go for 3/4 down the longest straight for initial gearing using info from the late Big Jim.
Don't be suprised however your torque INCREASES.
Maggot
03.11.2009, 05:33 PM
Torque increase???
I'd best start pulling that "throttle" curve.
As I have only run it on the tarmac outside the house, I have only been able to judge it against the Losi 8 C6bbt that I have run in the same place. I'm new to this electric RC so I am stunned by the torque it has now. I know the tyres it came with are on the soft but I can lay four black lines with this thing and after only 3 mins of running I could drive the thing sideway down the street on opposite lock. I didn't think it was possible to drift an 1/8 buggy but this, I can. The top speed on the Losi C6bbt is, at this time, is a fair chunk faster. I expect the EX to be faster around the track if I can tune the suspension to the Losi level, not of outright grip but driveability.
Thanks for all the input guys.
crazyjr
crazyjr's Avatar
03.11.2009, 07:18 PM
with all that torque, you should be able to gear up nicely
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.11.2009, 07:51 PM
Your pictures have vanished.... Time to call the ATHF!
