Can you say epic failure?!
Can you say epic failure?! - 05.26.2009, 12:25 PM
So I was searching around for smoking deals, as I usually do while I am at work, and stumbled across this.
http://www.impaktrc.com/product_info...oducts_id=2629
Good price for a BL motor, especially if someone wanted to do a HV setup in a rustler/pede. Not going to set the world on fire, but would pair nicely with a lower mah 5s lipo and some sort of esc (quark 65, maybe a MM).
Now impact are saying that this will run an 1/8 buggy? Not sure what gearing you would need to make this survive, but it would have to be low...like a 12t. That would give 32mph, and even them might be too much for the little feigao. I have run lower winds of the s can and they are decent motors, but not up to running an 1/8 scale 4wd buggy, maybe a crt.5?
