I got a little project I'm trying to put together. Can anyone tell me which 23mm hubs are the best? I need the kind that uses the 23mm nut against the wheel instead of the small locknut used stock. Kind of like the ProLine setup, except stronger. I heard the PL adapters break pins all the time.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
I've had a set of Dace hubs. I liked them but they're still pricey. Plus they use the 14mm hex in the middle. I was also looking at the Dynamite hubs but I'll look into the HPI units too. Thanks!
