Originally Posted by Blaz
hey guys my hot bodies d8 showed up today and it showed up with a mamba monster v3 esc and a fiegao fg 36 motor.i am running this on 5s and i was wondering how hot shuld the motor get because mine got up to 217.And also is this motor as good as the 2200kv mamba motor.i had tons of fun driving it today.it also has a rc monster hb d8 motor mount.but the onlyt bad thing was that it has a crappy pinion in it and my 2nd question is what pinion shuld i get and what tooth.also what would be the best set up for racing as far as gear wise spur and pinion.Thanks.
Fiegao and the Castle Neu are not even close in performance.. LOL The Castle is a ton more efficient, is capable of more hp, and will run a ton cooler and have longer run times on the same config. They may be at similar kv ratings, but that is all they have in common :)
PS at 200 (or more) your motors magnets start to demagnetize and you do damage.. Running that same setup the castle would be 130-160 range at most. If you don't get a Castle Neu, at the very least get a Medusa v2 60mm, don't forget to use the discount code if it's still listed.
