Moving from MT to Truggy
crazyjr
crazyjr's Avatar
Moving from MT to Truggy - 04.19.2010, 05:40 PM
I am moving to my truggy from my revo, I am moving the setup from the MT to the truggy. The motor is a 1515/2.5d/f neu motor the esc is a quark 125 w/koolflight UBEC, The plan is for 4-6s lipo use. My only question is, I have a 19 and a 20 tooth pinion at 1.0 mod. Can i run the truggy on the 2.5D with these pinions? Or, would it overheat with that gearing? I know the 2.5D 1515 is a torque monster.
here is the calculator for the 19 pinion At 4s lipo
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 48
Pinion Tooth Count: 20
Total Voltage: 14.8
Motor KV: 1650
Tire Diameter (inches): 5.65
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.01
Spur/Pinion Ratio: 2.4 : 1
Total Ratio: 10.32 : 1
Tire Circumference (inches): 17.75 inches (450.85 mm)
Rollout: 1.72:1
Total Motor Speed: 24420 RPM
Vehicle Speed: 39.77 mph (63.89 km/h)
Effective KV Value: 1650
KT constant: 0.82 oz-in/A
