Mugen MBX5-T Spur Gear Rubbing
Krawlin
Got brushless?
Krawlin's Avatar
Mugen MBX5-T Spur Gear Rubbing - 06.21.2009, 02:49 PM
I have a Mugen MBX5-T and it has a problem with the spur gear rubbing the radio tray. Every time I apply brake, the throttle/brake servo pulls the radio tray into the spur. I have flexed the chassis as much as I could to see if the spur would contact the radio tray and it never does, only when I apply brake.
I Dremel'd the stock aluminum tray so that it would get rid of the problem, which it did, but now I have a King Headz radio tray ( http://www.amainhobbies.com/product_...io-Plate-Black ) and the material that goes behind the servo is very narrow and the spur is contacting the radio tray again.
I am afraid to Dremel this King Headz tray because I plan on getting a stronger throttle/brake servo soon, as the one I have now is weak but still enough to pull the tray into the spur, and if I dremel it now and get a stronger throttle/brake servo, it will probably just pull the tray into the spur again.
I currently have the aluminum radio tray post, but I am wondering if I got this - http://www.amainhobbies.com/product_...dio-Tray-Mount - if it would keep the throttle/brake servo from pulling the radio tray into the spur when I apply the brake?
Has anyone else had this problem?
Thanks for any help!
Monster GT Conversion
brushlessboy16
brushlessboy16's Avatar
06.21.2009, 03:07 PM
lower your brake endpoints. or take a small turnbuckle and run it from the top of the center diff to the radio tray.. should eliminate the flexing and give you better braking.
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
06.21.2009, 09:59 PM
That sounds like a good idea. It sounds like your EPAs aren't set and it's causing the flex (and premature failure of your servo!) while under all that load.
I would give the EPA adjustment a shot first, then try the turnbuckle mod he mentioned.
:D
