Hyperion 720i... confusing..
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
Hyperion 720i... confusing.. - 06.25.2009, 09:53 PM
Hey guys, just got my 720i in the mail finally... K, when I go to start a charge, is it balancing as well? I would think so, it's just that I can't access each cells voltage when charging...
Or is the 720i taking good care of me? thanks.
06.25.2009, 10:09 PM
As long as you have the balancing connector connected you should be good to go. You do need to be in balancing charge mode, but the instructions should point you in the right direction.
The mode button should allow you to swap into the balancing screen when you are charging and the up and down keys should allow you to view each cell individually and all of them as a whole.
This info is based on the hope that the 720i works like the 610i...
06.25.2009, 10:18 PM
hit the menu buttom to show balancing and then up down to cycle screen through display - one of them shows all cells at once...
Failing that I'll buy the charger from you...
zeropointbug
Z-Pinch racer
06.25.2009, 10:57 PM
Oh yah, I got it now... catching on pretty quick.
You would think they could make the menu's more straight forward, with a few extra buttons?
thanks
06.25.2009, 11:00 PM
Once you get used to using a hyperion it gets pretty easy. I still screw up the lipo setup screen, but I just make a bunch of profiles, I do have 2 of the 610i chargers and 2 of the 12310i...
NoControl
NoControl's Avatar
06.25.2009, 11:03 PM
Besides I didn't think you could charge a lipo on a hyperion (newer models) without a balancer connected, I know my 610 won't even start the charge.
E-revo MMM 2200 6s zippy 50MPH of pure fun and parts destroying powa!
Futaba 3pk more controller then anyone person needs
TC5 top speed drifter 21mph on crappacks and 40 on calc
zeropointbug
Z-Pinch racer
06.25.2009, 11:20 PM
Yah, it says it can't charge without one. It will for an A123 pack however, as far I can see. Is this correct?
06.26.2009, 06:36 AM
No it just says balancer advised - Press enter and you can ignore it....
johnrobholmes
johnrobholmes's Avatar
06.26.2009, 08:47 AM
yep.
To access the cell voltage screen after charge starts hit the far left button once then up once.
---JRH---
zeropointbug
Z-Pinch racer
06.26.2009, 11:34 AM
Yah, looks like you can ignore it, the manual says otherwise however...
It's left twice, and then up once Johnrob...
Also, why is the charger cutting the current a regular intervals for a couple seconds at a time? Is this normal?
Does this model have cycling feature?
06.26.2009, 11:35 AM
Normal so it can get an accurate voltage read at rest
zeropointbug
Z-Pinch racer
06.26.2009, 11:41 AM
Okay, thanks, I figured that was why. Probably to read cell Ri ?
zeropointbug
Z-Pinch racer
06.26.2009, 12:39 PM
Oh hey, what should I be charging these Hyperion 25C 6s 4350mah packs at? 2C, or 1C? I can't see anywhere on the website where is mentions charging rate. thanks.
06.26.2009, 12:55 PM
Personally I always charge at 1c regardless of the label - you don't say what version hyperion you have
06.26.2009, 12:57 PM
HYPERION G3 CX can supposedly be charged at up to 5c
