Is it possible? -
08.08.2009, 10:22 PM
hey,guys
Is it possible to make a savage xl go 60+mph?If so what do i need?
08.08.2009, 10:46 PM
MMM,
1521 1y or 1527 1.5d
some 6s batteries probably 5000mah 30c or better
some very well balanced tires
Some balls. and a lots of diff parts.
RC-Monster Spudgunner
08.08.2009, 10:52 PM
With money. Lots of it.
08.08.2009, 11:56 PM
so if i had that stuff it would go 60mph+ also ill be using kewshawdiesigns dd
08.09.2009, 12:02 AM
Geared correctly yes
08.09.2009, 12:50 AM
what kind of gearing should i use?
08.09.2009, 01:01 AM
with which setup.
there are many out there. theres no real reason why you need a savage xl to go 60.. just a money pit that will suck up more money everytime it gets a little unsettled at 60
08.09.2009, 01:46 AM
With a well moded Picco .28 and the good gearing, you can do that
08.09.2009, 12:01 PM
i would be using kewshawdeisigns direct drive,mmm,1527 1.5d,and MaxAmps Green Series Life 4500 6S2P 19.8V Battery Pack
KillaHurtz
08.09.2009, 01:17 PM
That KD DD unit uses plastic gears... I can't imagine it would hold up to what you are proposing. Not sure if its enough batt either..
08.09.2009, 01:44 PM
if i use kewshawdeisigns direct drive,mmm,1527 1.5d,and MaxAmps Green Series Life 4500 6S2P 19.8V Battery Pack will it go 50mph?
Can't catch this...
08.09.2009, 02:33 PM
it will go faster than you can drive it...
08.09.2009, 02:46 PM
how fast i nedd to know asap
Fat Kid Engineering
08.09.2009, 02:55 PM
08.09.2009, 03:46 PM
stay away from maxamps
