Originally Posted by phildogg
Thanks brian will try the antenna did you buy a new spectrum antenna or just use a certain gauge and length wire?
phil
Check your batts in the remote too. Whenever my spektrum gets below 11v range begins to decrease.
As for the antenna wire, just use the same gauge and you will be fine. Iv'e done this many many times (especially when I had AM). If you want, (not sure if you can solder or not) I'd be more than happy to replace your antenna for you (free of charge of course). We are both in NC so shipping would be quick.
