Sorry for the title...lol
I'm a bit disappointed right now and looking for some guidance. I've been working on a top speed setup for my 1/16 Mini E-Revo for the past few weeks. I made the initial speed runs today and am less than impressed and very confused. Please review my setup and let me know if anything is way off base or any theories you may have for my lack of speed.
1/16 E-Revo
Stock diffs and tranny
EZRun 60A esc
Neu 1112/2D motor (3250kv rated)
ESC timing 15 degrees (this is the EZRUN default, not sure if that is best)
Custom motor mount (see below)
ParkBEC 6v
Ko Propo ex-5 UR radio/receiver
HS-5085MG servo
45t spur gear
Various pinion gears (35, 39, 43, 47)
2 - Hyperion G3 VX packs (2S, 1800mah) in series
HPI Super Nitro belted slicks and rims (measured 9.5" circ., 3.0" diam.)
So, as you can see, I made my own motor mount and tranny plate. The stock setup would not allow for any more than a 35t pinion and the Neu 1112 contacted the rear shock mount. So, I made this setup in my garage. This si the first time I've tried somethign like this. I don't have a mill or anything cool like that, just a drill press and hand tools, so be nice
Anyway, this setup can fit the largest pinion gear I can find (47t) with room to spare and the motor clears the shock mount.
I made a bunch of runs today and seemed to hit somewhat of a wall in the mid-60's (MPH). I ran everything from 35/45 gearing up to the big 47/45 gearing. Each run was between 62-66 MPH. Now, I never got a prolonged full throttle run, I usually came up to speed and was maybe just touching full throttle for a split second, if at all. Regardless, I expected to be running much faster. Additionally, I can't figure why my gearing changes had no noticeable effect on speed. I must have made 30 runs easily and they were all about the same. Normally, I would think this means the motor is just unable to push the truck any faster, but others have gone much faster on "lesser" motors. I expected this Neu would have enough power that it would be the last of my issues. Temps never got super hot. The motor was usually around 120-140, hitting 155 once after a long string of runs. The ESC never got above about 130 or so. I recalibrated the ESC once to make sure it was seeing full throttle from the radio. I also have a ziptie pulling the rockers together so that the suspension rests just above bottom.
BTW, for those that have not been following the mini revo. There are already a few folks that have recorded 81-82 MPH runs. One even managed it with a stock esc/motor on 4S, although he knows he is on borrowed time. I've spent lots of time on BrianG's tope speed calculator and see no reason why I am not going faster.
I have plans to hit a longer road tomorrow to see if I can get full throttle for a few seconds straight, but I'm not expected much of a change. This has been fairly disappointing for the money and time invested. I feel like I'm using the right parts, but maybe I missed something. Maybe my driving is an issue, just not sure. So tell me guys, what do you think?
Pics of my setup...Thanks!
