brushless conversion kit kyosho gt2
4g63t
Exclamation brushless conversion kit kyosho gt2 - 06.02.2009, 01:32 PM
Mike do you make a brushless conversion kit kyosho gt2?
not the novak kit
nitrostarter
nitrostarter's Avatar
06.02.2009, 01:46 PM
http://www.rc-monster.com/proddetail...rcmkyoshomount
Pretty sure thats what you are looking for.
N. Rustler conversion
4g63t
06.02.2009, 01:47 PM
ok so theres not a kit
nitrostarter
06.02.2009, 01:53 PM
As far as I know, no kit. But a little innovation will lead you in the right path. Battery trays aren't hard to make, motor placement is pretty pre-determined, servo placement can be tweaked as well as ESC placement.
Do a search and look around for other combo's. Joe Ford of Castle has recently converted one if I'm not mistaken.
4g63t
06.02.2009, 01:55 PM
[QUOTE=nitrostarter;292260]As far as I know, no kit. But a little innovation will lead you in the right path. Battery trays aren't hard to make, motor placement is pretty pre-determined, servo placement can be tweaked as well as ESC placement.
Do a search and look around for other combo's. Joe Ford of Castle has recently converted one if I'm not mistaken.[/QU
thanks
jnev
jnev's Avatar
06.02.2009, 05:54 PM
Here is a battery tray:
http://www.rc-monster.com/proddetail...MFPbatterytray
So all you need for the conversion is this tray and the motor mount nitrostarter linked to.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
06.02.2009, 06:17 PM
I also have a double-servo tray that i haven't listed yet, along with the 2 speed adapter and 2 speed gears if you wish to retain the 2 speed. i also made a single speed adapter that fits Revo/Jato spurs to the stock 2 speed shaft - again, I haven't listed these, as I have not had time to produce a batch yet. :)
4g63t
06.02.2009, 08:35 PM
can you make me a KIT
RC-Monster Mike
Site Owner
06.02.2009, 08:43 PM
Yes, I suppose I could offer a kit easily enough. :)
06.02.2009, 09:37 PM
Mike, this is what I called you about earlier...
RC-Monster Mike
Site Owner
06.03.2009, 09:57 AM
Got your message this morning, Brian - thanks. :)
Mechanical break vs. ESC break
atmhobby
Mechanical break vs. ESC break - 06.04.2009, 09:46 AM
Hello,
I am working on a conversion for my kyosho gt2, and was wondering what the advantages are of using the mechanical break vs the break from the ESC? I have a mamba monster ESC.
nitrostarter
06.04.2009, 09:57 AM
How fast are you planning to go?
Most use mechanical brakes when using the 2-speed since its a clutch-type operation, theres no way to apply effective motor brakes.
However, if using a regular center diff or spool in the center, motor brakes work great.
Also, depending on your Radio choice, theres also the choice to mix in both motor and mechanical brakes. For example, on the Airtronics M11, you can plug a mech brake servo in the 4th channel spot and mix it in specifically for braking uses only, to assist the motor in braking duties.
atmhobby
06.04.2009, 10:04 AM
I just want to be able to beat the nitro guys on our parking lot track. I have a losi8 with 2200kv/ motor 15/45 and it was not quick enough. I just want my gt2 to be much faster. I have never had an on road car before with a 2speed. Where could I get a regular center diff that fits the gt2?
Thanks for your help!
RC-Monster Mike
Site Owner
06.04.2009, 10:17 AM
The Losi8 with the 2200 combo can be volted and geared to beat the nitro guys pretty easily. A Kyosho diff will fit the GT and GT2, but you would need to space the driveshafts and use a buggy top plate. The IGT and IGT2 are basically 1/8 buggies with a 2 speed and car body.
