1/10 sidewinder on 4s?
eovnu87435ds
A 16yr old with a combover
1/10 sidewinder on 4s? -
08.17.2009, 03:57 AM
I know the mamba max will run up to 5s(if you discharge half a volt first so it will arm) but does the sidewinder have similar components?
I want to use it in a rc18b with a setup that will draw no more than 30 amps or so and want to run it on 4s. will it?
This is the 1/10th sidewinder, not the micro one.
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
eovnu87435ds
Find all posts by eovnu87435ds
2
Metallover
RC-Monster Spudgunner
08.17.2009, 07:48 AM
In an rc18 it should handle 4s no problem.
You might need a bec.
Metallover
Find all posts by Metallover
3
shaunjohnson
i pwn nitro
08.17.2009, 08:00 AM
ditto on the bec
shaunjohnson
Find all posts by shaunjohnson
4
Finnster
KillaHurtz
08.17.2009, 11:04 AM
I run mine on 4S w/ a BEC in my CRT.5. Perfect.
Finnster
Find all posts by Finnster
5
Brushless Moose
09.13.2009, 02:08 AM
LVC still work?
Brushless Moose
6
Sammus
09.13.2009, 02:10 AM
i run mine with 4s a123 all the time with no ext. bec... works like a charm :p
Sammus
Find all posts by Sammus
Linear Mode
Switch to Threaded Mode
Off
