Just a thought
brushlessboy16
brushlessboy16's Avatar
Just a thought - 09.22.2009, 12:29 PM
Anyone ever consider, or try running a low turn (18.5, 21.5) novak/lrp (roar sensored) motor on 4s through something like an rx8?
Sensored startups, low kv(~2500kv) and high voltage to finally find a spot where these motors would run cool?
Im thinking about running this setup in my slash with buggy tires..
Any input?
MetalMan
MetalMan's Avatar
09.22.2009, 12:41 PM
In a 2wd ST I ran a Trinity 13.5 on 3s Lipo, but sensorless. The power of these motors simply is weak in comparison to other stuff I have run, including CC motors. But if you already have the motor laying around then it's not such a bad idea
nitrostarter
nitrostarter's Avatar
09.22.2009, 01:02 PM
I definitely wouldn't go out of my way to get one of these motor's to try either. They may work well but the numbers aren't there...
N. Rustler conversion
lutach
lutach's Avatar
09.22.2009, 01:18 PM
Did it in my TC3 and it's fun . I was testing my ESC with 4S using the internal BEC and it did pretty good.
nitrostarter
09.22.2009, 01:21 PM
I think the TC3 is a different situation than the slash tho...
brushlessboy16
09.22.2009, 01:22 PM
Was thinking about the Tekin 10th scale motors.
nitrostarter
09.22.2009, 01:28 PM
Do u have one? or going to buy one?
brushlessboy16
09.22.2009, 01:51 PM
No was just a thought.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.22.2009, 02:12 PM
Well there is this on-road carpet track near where I live. If I run stock class I'll have to buy a 17.5 motor. The esc will be the MM pro, and of course I am going to test it with my Hyperion G3 3300 mAh 6s pack, so there you go...
Area 52 Ranch Raceway
T.R.C.R.
Semi Pro
Semi Pro's Avatar
09.22.2009, 05:27 PM
you should as the tekin rep
i think a low kv tekin motor will hold up fine, as for novak......well
